Previous Topic: ToS Summary (Pie)Next Topic: Interface: Top Conversations
ToS Summary (Table)
The ToS Summary (Table) views show rate, volume, or utilization for the top ToS values of the traffic on a particular interface. You can use this information to compare traffic for each of the top ToS values.
The example graphic shows the view in the CA Performance Center Console. The table shows the rate for each listed ToS value. You can configure the view to display rate, utilization, or volume information.
The ToS Summary Table views show the rate, utilization, or volume of the top ToS values on the interface.
An interface identification string is shown under the view title. The table contains a row for each ToS with the Type of Service identifier (EF/AF, DSCP, and ToS values) and the following rate, volume, or utilization information:
Performance Center views show the data from the time range that is defined for the page.
Opening the View
To see this view in the Performance Center Console, go to one of the following locations:
Available Actions
You can perform several actions in this view, including the following ones:
Find ToS Summary Tables in the NFA Console
You can display ToS summary tables in the NFA console for a selected interface:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
