Previous Topic: Top Conversations (Pie)Next Topic: Interface: Top Hosts
Top Conversations (Table)
The Top Conversations (Table) views show data for the top highest-volume conversations on a particular interface. The maximum number of top conversations shown is ten.
The example graphic shows a Top Conversation (Table) view in the CA Performance Center Console, which is set to show conversation rates. You can configure the view to display rate, utilization, or volume information.
The Top Conversations Table views show the rate, utilization, or volume of the top conversations on the interface.
The table contains a row for each conversation with the source and destination - The fully qualified DNS host name (if available) and IP address of the servers that initiated and received the conversation data. The table also contains the following rate, volume, or utilization information:
Performance Center views show the data from the time range that is defined for the page.
Opening the View
To see this view in the Performance Center Console, go to one of the following locations:
Available Actions
You can perform several actions in this view, including the following ones:
Find Conversation Tables in the NFA Console
You can display tables with conversation volumes in the NFA console for a selected interface:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
