Previous Topic: Top Protocols (Pie)Next Topic: CA Anomaly Detector Views in Performance Center
Top Protocols (Table)
The Top Protocols (Table) views are tables that show the rate, volume, or utilization for the highest-volume protocol traffic on a particular interface. You can use this information to compare the data volume or utilization for particular protocols, for example.
The example graphic shows a Top Protocols (Table) view in the CA Performance Center Console. The view is set to show the traffic volume for each listed protocol. You can configure the view to display rate, utilization, or volume information.
In a Top Protocols Table view, you can see rate, volume, or utilization of the top protocols.
The view contains an interface identification string and table. The table has a row for each protocol with the protocol name (keyword and TCP/UDP port assignment) and the following rate, volume, or utilization information (by default):
Performance Center views show the data from the time range that is defined for the page.
Opening the View
To see this view in the Performance Center Console, go to one of the following locations:
Available Actions
You can perform several actions in this view, including the following ones:
Find Protocol Tables in the NFA Console
You can use these ways to display tables of protocol volume data in the NFA console for a selected interface:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
