Previous Topic: Configure CA Performance Center to Use HTTPSNext Topic: Glossary
Update Single Sign-On Configuration and Restart the Services
Edit some startup files to support SSL encryption in Single Sign-On. You must also restart all CA Performance Center and Single Sign-On services to update the settings.
  1. Change to the following directory:
    cd/[InstallationDirectory]/CA/PerformanceCenter/sso
  2. Open the start.ini file for editing.
  3. Find the following line and remove the '#' so that it is active:
    #/opt/CA/PerformanceCenter/sso/etc/jetty-ssl.xml
    where '/opt/CA' is the default installation directory.
  4. Save start.ini.
  5. Change to the following directory:
    cd/[InstallationDirectory]/CA/PerformanceCenter/sso/etc
  6. Create a file named jetty-ssl.xml in that directory with the following contents:
    <?xml version="1.0"?>
    <!DOCTYPE Configure PUBLIC "-//Jetty//Configure//EN" "http://www.eclipse.org/jetty/configure.dtd">
    <Configure id="Server" class="org.eclipse.jetty.server.Server">
      <Call name="addConnector">
        <Arg>
          <New class="org.eclipse.jetty.server.ssl.SslSelectChannelConnector">
    	     <Set name="Port">8382</Set>
    	     <Set name="maxIdleTime">30000</Set>
            <Set name="Keystore"><Property name="jetty.home" default="." />/etc/keystore</Set>
    	    <Set name="Password">***PASSWORD***</Set>
    	    <Set name="KeyPassword">***PASSWORD***</Set>
           <Set name="truststore"><Property name="jetty.home" default="." />/etc/keystore</Set>
            <Set name="trustPassword">***PASSWORD***</Set>
            <Set name="allowRenegotiate">true</Set>
          </New>
        </Arg>
      </Call>
    </Configure>
  7. Replace all instances of the “***PASSWORD***” value with the passwords in use in your system.
  8. Save jetty-ssl.xml.
  9. Open the file jetty.xml.
  10. Remove the following lines for the default HTTP connector:
      <Arg>
          <New class="org.eclipse.jetty.server.nio.SelectChannelConnector">
              <Set name="host"><Property name="jetty.host" /></Set>
                <!-- Changed: Used to be Property -->
               <Set name="port"><SystemProperty name="jetty.port" default="8181"/></Set>
               <Set name="maxIdleTime">300000</Set>
               <Set name="Acceptors">2</Set>
               <Set name="statsOn">false</Set>
               <Set name="confidentialPort">8443</Set>
               <Set name="lowResourcesConnections">20000</Set>
               <Set name="lowResourcesMaxIdleTime">5000</Set>
          </New>
      </Arg>
     </Call>
  11. Save jetty.xml.
  12. Change to the following directory:
    [InstallationDirectory]/CA/PerformanceCenter/sso/conf
  13. Edit the file wrapper.conf. In the following line, replace '8381' with '8382' so that it matches the port defined in jetty-ssl.xml, described previously:
      wrapper.java.additional.2=-Djetty.port=8381
  14. Save wrapper.conf.
  15. Stop the console, device manager, and SSO services by entering the following commands:
    service caperfcenter_console stop
    service caperfcenter_devicemanager stop
    service caperfcenter_sso stop
  16. Restart the services by entering the following commands
    service caperfcenter_sso start
    service caperfcenter_devicemanager start
    service caperfcenter_console start
