Create NBAR2 (Next Generation Network-Based Application Recognition) application mapping rules to identify NBAR2 application traffic in reports. NBAR2 rules can identify traffic for individual applications, combine traffic for multiple applications, or separate NBAR2 traffic from other traffic.
If multiple rules map traffic to the same destination port, the program gives the rules the same name--the name you specified most recently. The rule name is the label for the NBAR2 traffic in reports.
This topic describes how to create NBAR2 application mapping rules individually on the Applications Definitions page. You also can batch import NBAR2 application rules by using the command line. For more information about command-line import options, see the topics beginning with Import Application Mapping Rules.
Notes:
The Application Definitions page opens.
The Add Application Mapping dialog opens.
The dialog switches to NBAR2 rule mode.
Specify the application ID correctly or the rule does not function as expected. The application IDs are included in the nbar2.csv file in the following folder: <install_path>/reporter/racmd.
If you specify a destination port that is already used by other rules, the traffic for the related rules will be combined.
(Optional) Click Check to run a general check to detect whether the specified port is already receiving data. The check fails if the port is receiving native data--that is, data that is not mapped by application mapping rules. If any native data is on the specified destination port, that data is redirected to the rebase port.
The rule name also is the label for the mapped traffic in certain reports. If other rules map traffic to the same destination port that you specify for this rule, specify the name that you want to use for the combined traffic.
Note: The NBAR2 Engine ID value is pre-populated and cannot be edited. The value is 13, the standard NBAR2 engine.
The dialog closes. The new rule is added to the Application Mapping rule list. If any other rules map traffic to the same port and you specified a new rule name, the other rule names are updated.
