The Application Response Time reports show Cisco's Application Response Time (ART) metrics. ART metrics are available for IPFIX flows from routers that have Cisco ART metrics enabled.
Meaningful data is shown in the Application Response Time reports under the following conditions:
If a router is not configured to return data for the appropriate fields, a zero (0) appears in the corresponding table cells. Non-NBAR2 traffic shows a zero for all of the values except the router IP address and application name.
The Application column values show the NBAR2 application name followed by the application ID. The application name is included if it is defined by the standard (not custom) NBAR2 engine. Otherwise the Application value may consist of only the application ID.
The Application Response Time group of Flow Forensics reports show the following fields.
Report |
Router Addr |
Application |
Transactions |
Avg Total |
Late Responses |
Retransmissions |
Client Address |
Server Address |
New Connections |
Avg Client |
Avg Server |
Avg Response Time |
Avg Application Delay |
Application Metrics |
Y |
Y |
Y |
Y |
Y |
Y |
Client Side Metrics |
Y |
Y |
Y |
Y |
Y |
Y |
Server Side Metrics |
Y |
Y |
Y |
Y |
Y |
Y |
Displays a summary of ART metrics for IPFIX flow that includes NBAR2 data. The report table includes a row for each unique combination of the following values:
Displays client-side ART metrics for IPFIX flow that includes NBAR2 data. Each row shows the values for a unique combination of the following values:
Displays server-side ART metrics for IPFIX flow that includes NBAR2 data. Each row shows the values for a unique combination of the following values:
