Edit the details for Harvesters on the Harvester page. You can edit the IP address, description, and tenant-domain setting.
The Harvester page opens and displays a table of information about known Harvesters.
The Edit Harvester dialog opens.
Address of the Harvester
(Optional) Additional information to help identify the Harvester on the Harvester page
The tenant-domain association of the Harvester in a multi-domain deployment.
Changing this setting affects the tenant-domain association for any new routers that begin exporting flow data and any new interfaces that begin generating flow. Already existing routers and interfaces retain their previous tenant-domain associations.
The domain affects which operators and reports have access to the data from routers and interfaces.
Changing the tenant of a router in CA Performance Center can affect which SNMP profiles are available for polling the router's interfaces. This is not true for CA NetQoS Performance Center, which uses the same list of SNMP profiles for all routers.
Default: Default Tenant\Default Domain
If no custom IP domains have been created, the Harvester table includes only the IP Address and Description columns.
Your changes are saved immediately and appear in the Harvester table.
