The Session group of Flow Forensics reports show the following fields.
Report |
Router Addr |
Interface In |
IP Protocol |
Src Addr |
Src Addr (IPv6) |
Src Port |
Interface Out |
Dest Addr |
Dest Addr (IPv6) |
Dest Port |
ToS |
Bytes |
Rate (Bits) |
% Total (Bytes) |
Flows |
Flow Duration |
Pkts |
Rate (Pkts) |
% Total (Pkts) |
Engine |
Application |
Client-Server Sessions |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Conversation Sessions |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Conversation Sessions (NBAR2) |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Conversations |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Conversations (IPv6) |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Conversations (with Interfaces) |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Destination Applications |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Destination Endpoints |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Protocols |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Server-Client Sessions |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Source Applications |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Source Endpoints |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Y |
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of each session that had a unique combination of the following values:
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count and cumulative flow duration of each conversation session that had a unique combination of the following values:
Displays conversation session traffic and identifies any NBAR2 (Next Generation Network-Based Application Recognition) data that is included. The report table includes a row for each unique combination of the following values:
If a router is not configured to return NBAR2 data, a zero (0) appears in its rows under the Engine and Application columns. If other columns contain a zero for the router rows, the router may not be configured to return the fields for those values.
The Application column values show the NBAR2 application name followed by the application ID. The application name is included if it is defined by the standard (not custom) NBAR2 engine. Otherwise the Application value may consist of only the application ID.
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic for each IPv4 address pair that had a unique combination of the following values:
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic for each IPv6 address pair that had a unique combination of the following values:
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of each conversation that had a unique combination of the following values:
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic that had a unique combination of the following values:
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic that had a unique IP protocol.
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of each traffic session that had a unique combination of the following values:
