Previous Topic: Drill Down to Details About a HostNext Topic: Open Interface Reports
Interface Reports
You can review your network traffic by using one of the built-in reports or you can create customized reports, which you can save and run whenever you choose. While the Enterprise Overview provides a quick view of your network, the Interfaces page provides in-depth reports. The following topics describe how to use the Interfaces page. Learn how to generate reports for individual interfaces.
This section contains the following topics:
Interface Report Types
Work with Interface Reports and Data Views
Change the Interface for a Report
Set the Time Period for a Report
Set the Presentation Options
Analyze Interface Report Data
Display Charts and Graphs
