Previous Topic: 1-Minute DataNext Topic: Databases to Back Up
How to Back Up and Restore Data
Use the procedures in this section to back up and restore the CA Network Flow Analysis databases. You can back up CA Network Flow Analysis databases manually, as described in this section, or back up the databases automatically. To back up databases automatically, add the appropriate directories to your regular backup routine, such as:
Important:
Consider the general recommendations for backup frequency.
Before you back up large databases, consider how much disk space the backups will require and the lifespan of the files you are backing up. You probably will not want to back up the raw flow data (.NFA files) or back up the entire datafiles directory.
More information:
Back Up the Databases
Restore the Databases
