Previous Topic: Configure Global Settings for Application MappingNext Topic: Create a Host Application Mapping Rule
Create an All (ToS) Application Mapping Rule
Create an All application mapping rule to combine, separate, or more clearly identify traffic by its ToS (Type of Service) value.
  1. Open the Application Definitions page:
    1. Select Administration from the NFA console menu.
    2. Select Application Definitions in the Administration menu.
    The Application Definitions page opens.
  2. Verify that Application Mapping is the selected value for Rules.
  3. Click Add Rule.
    The Add Application Mapping dialog opens.
  4. Select All from the list of rule types at the top of the dialog.
    The Add Application Mapping dialog switches to All (ToS) rule mode.
  5. Specify the setting values:
  6. Click Save.
    The dialog closes. The new rule is added to the Application Mapping rule list. If any other rules map traffic to the same port and you specified a new rule name, the other rule names are updated.
  7. (Optional) Run reports to verify that the traffic on the designated destination port fits the rule.
  8. (Optional) Review the effects of the new or changed application mapping rules on reports, then consider renaming the rule to label the mapped traffic more clearly in reports.
