Administering CA Network Flow Analysis › View Physical and Virtual Interfaces › Review the Active Interface Page Options
Use the Active Interfaces page to view and manage active routers, interfaces, and custom virtual interfaces (CVIs).
- Open the Active Interfaces page:
- Select Administration from the NFA console menu.
- Select Interfaces: Physical & Virtual from the Administration menu.
The Active Interfaces page opens, which lists the current routers and their active interfaces.
The Active Interfaces page includes the following options:
- Search options: Search for routers, interfaces, or custom virtual interfaces (CVIs) whose addresses or names match a text string. To clear the search, click Clear Filter.
- Edit: Modify several of the attributes of a router, interface, or CVI.
- Merge: Combine the data for two or more selected physical interfaces or two or more selected CVIs.
- Add Custom Virtual Interface: Create a custom virtual interface that is based on the selected physical interface.
Router Table Elements
Routers are listed on the Active Interfaces page in the form of tables. The router tables contain the following columns.
Table Columns
- Last Poll: Status of the router at the most recent poll:
- Red: Router was not detected.
- Yellow: Router was detected, but no flow data was received from it.
- Green: Router was detected and flow data was received from it.
- Router Address: IP address of the router
- Router Name: User-assigned name of the router, such as lab1 router
- Template: Template that is associated with the application
- Interfaces: Total number of interfaces the router has
- Harvester: IP address of the Harvester that collects data from the router
Interface Table Elements
Interfaces and custom virtual interfaces (CVIs) are listed on the Active Interfaces page in tables nested under their parent routers. To display the interfaces and CVIs for a router, click the arrow next to the router name. Interface tables contain the following elements and columns.
Table Columns
- Traffic Status: Status of the interface at the most recent poll:
- Red: Inactive interface
- Green: Active interface
- Class: Interface type: a physical interface or a custom virtual interface (CVI). The physical interface icon is a gray box with the letters INT. The CVI icon has a V next to the box.
- Interface Name: User-assigned name of the interface or CVI
- Description: Optional information that an Administrator added to help identify the interface or CVI
- If Index: Index value that is assigned to the interface. The If Index value for a CVI matches the value for the parent interface.
- Type: Connection type, such as WAN, LAN, or VLAN
- In Speed: Inbound speed of the interface or CVI, provided the speed is known
- Out Speed: Outbound speed of the interface or CVI, provided the speed is known
- Domain: Domain of the interface. If the environment has only one domain, the Domain column is not visible. To view the tenant association in CA Performance Center, select the check box next to the interface, then click Edit.
- Notes: Link to any notes that the Administrator has added for the interface or CVI
