Previous Topic: Interface: Stacked Trend ChartsNext Topic: Stacked ToS Trend
Stacked Protocol Trend
The Stacked Protocol Trend views in CA Performance Center show the top protocols that are used the most heavily for traffic on the selected interface. The views also show when the traffic occurred.
The example graphic shows a Stacked Protocol Trend view that shows a timeline of rates for each listed ToS value. You can configure the view to display rate, utilization, or volume information.
Stacked Protocol Trend views show the type of traffic consumed on an interface and the time of consumption.
The view includes the following information:
Identifier
Consists of the router name, interface name, and interface description (under the view title). The interface description consists of the ifDescr value by default, so it may be slightly different than the interface description that is shown in CA Network Flow Analysis.
Protocol Bands
Show the data rate, data volume, or interface capacity utilization for each Top N Protocol that is associated with traffic on the interface.
Time (All Views)
Point in time during data transmission--expressed in hours and minutes (X-Axis).
Measurement Setting:
Depending on the data direction, the data is inbound to the interface, outbound from the interface, or both.
Legend
Identifies the protocol for each color band by protocol keyword and tcp/udp port (bottom of the view).
By default, views and reports show the most recent 24 hours of data.
To see the Stacked Protocol Trend views in CA Performance Center, go to one of the following locations:
Available Actions for This View
You can perform several actions in this view, including the following actions:
Find Protocol Trend Data in NFA Console Views and Reports
You can display protocol volume in the NFA console in trend charts or stacked trend charts for a selected interface:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
Also See:
Top Protocols (Table)
Top Protocols (Pie)
Top Protocols (Bar)
