To begin using SAML 2.0 for user authentication in CA Performance Center, set some parameters on the identity provider (IdP). Any IdP that supports the SAML 2.0 standard should work, but CA has only tested with CA SiteMinder.
Here is an example:
http://[MyServerName]:8381/sso/saml2/UserAssertionService
where 8381 is the port that Single Sign-On uses.
Note: HTTP Redirect is the only binding method that Single Sign-On supports.
The logout service and the response location are both required. These services are running on the server where Single Sign-On is installed.
Use the following examples:
http://[MyServerName]:8381/sso/saml2/LogoutService http://[MyServerName]:8381/sso/saml2/LogoutServiceResponse
This step can involve adding these websites to a list of federation partnership entities.
You exported this file after you completed other setup steps using the Single Sign-On Configuration Tool. For more information, see Configure SAML Support in Single Sign-On.
