Previous Topic: Authentication MethodsNext Topic: Single Sign-On Configuration Tool
Data Source Support
CA Single Sign-On supports all of the following data sources:
The Single Sign-On Configuration Tool was designed to run on Linux systems. However, you can also deploy it on the Windows servers where data sources are installed. If you launch the Configuration Tool from a Windows server, log in as an Administrator on that server.
You can also run the Configuration Tool on Linux and send configuration instructions to data sources running on Windows by using the Remote Value option.
The Configuration Tool is installed in the following directory location on Linux:
[InstallationDirectory]/CA/PerformanceCenter
On Windows servers where the data sources are installed, the Configuration Tool is installed in the following directory:
[InstallationDirectory]\Portal\SSO\bin\SsoConfig.exe
