Single Sign-On provides authentication services to CA Performance Center and supported data sources. It also supports external authentication schemes, such as LDAP and SAML 2.0. This support lets you integrate CA Performance Center and other CA data source products into the same authentication scheme, enterprise-wide.
The Single Sign-On security auditing feature logs information about who is logging in, and at what time of day. On Linux servers, the log is saved in the following location:
[InstallationDirectory]/PerformanceCenter/sso/logs
And on Windows servers where the data sources are installed, the log is saved in the following directory:
[InstallationDirectory]\Portal\SSO\logs
