In a distributed deployment, the NFA console and Harvester are installed on separate servers.
CA tested the CA Network Flow Analysis solution with the following recommended minimum hardware configuration. Your requirements may vary depending on the number of interfaces, applications, and users in your network.
Note: The recommended specifications described here apply to both physical and virtual deployments. The requirements represent the configuration of CA appliances that are currently shipping. You can run CA Network Flow Analysis successfully if your configuration does not meet these specifications, although your performance may vary. You can also run CA Network Flow Analysis on a configuration that exceeds these specifications.
The server that hosts the NFA console has the following recommended minimum specifications.
The server that hosts the Harvester has the following recommended minimum specifications.
