Uninstalling CA Network Flow Analysis
The CA Network Flow Analysis 9.1.2 includes an option to uninstall the product, which you can use to remove CA Network Flow Analysis after an installation or upgrade.
Notes:
- The Uninstaller has no Undo option: Once you uninstall the software, you cannot restore the deleted files automatically.
- You should be able to install and uninstall the CA Network Flow Analysis software once or twice without incident. If you have ongoing problems, we recommend that you contact CA Support rather than continue to install and uninstall the software.
This section contains the following topics:
Uninstallation Prerequisites
Uninstall CA Network Flow Analysis
