Preparing Windows Servers for the Upgrade › Configure DEP
Configure DEP
Data Execution Prevention (DEP) helps to prevent code executing from data pages. We recommend that you configure the DEP policy as described in this topic.
- Log in to the server as an administrator.
- Open the Advanced tab of the System Properties dialog. For example:
- Select Start and right-click Computer.
- Select Properties from the menu.
The System window opens.
- Click "Advanced system settings" on the left.
The System Properties dialog opens with the Advanced tab displayed.
- Click Settings in the Performance section.
The Performance Options dialog opens.
- Click the Data Execution Prevention tab.
- Select "Turn on DEP for essential Windows programs and services only."
- Save your settings and exit:
- Click OK in the Performance Options dialog.
Your settings are saved and the dialog closes.
- Click OK in the System Properties dialog.
- A message opens and informs you that you must restart your system to make the new settings take effect.
- (Optional) Restart your system before you install or upgrade the software.
If you proceed with software installation or upgrade without restarting the system, the prerequisite test displays a warning about your DEP configuration
