Preparing Windows Servers for the Upgrade › Enable IIS, COM+, and ASP
Enable IIS, IIS 6 Management Compatibility mode, COM+ Network Access, and ASP on a standalone installation server or an NFA console installation server.
- Log in to the server as an administrator.
- Select Start, Administrative Tools, Server Manager.
The Server Manager window opens.
- Expand the Roles list in the Console tree on the left.
- Add the IIS role service:
- Click the Application Server link under Roles in the Console tree on the left.
The Application Server view opens in the right pane.
- Click the Add Role Services link in the Role Services section.
The Add Role Services wizard opens to the Select Role Services page.
- Select the Web Server (IIS) Support check box.
A confirmation message appears.
- Click Add Required Role Services in the confirmation message.
The Web Server (IIS) Support option is highlighted on the Select Role Services page.
- Add the COM+ role service:
- Select the COM+ Network Access check box.
- Click Add Required Role Services in the confirmation message, then click Next.
The Web Server (IIS) page of the Add Role Services wizard opens.
- Enable IIS 6 Management Compatibility:
- Click Next again.
A list of role services appears in the wizard.
- Select the IIS 6 Management Compatibility check box in the Management Tools section of the list, then click Next.
The Confirm Installation Selections page summarizes your actions and displays related messages.
- Install the IIS and COM+ role services and options you selected:
- Click Install.
The Progress page is shown until the installation is complete, when the Results page opens.
- (Optional) Click ‘Print, e-mail, or save the installation report, review the information,’ then close the page.
The Installation Report page displays a summary of your changes, information about the changes, and the location of the full installation log.
- Click Close.
The Results page closes.
- Add and install the ASP role service:
- Click the Web Server (IIS) link under Roles in the Console tree on the left.
The Web Server (IIS) view opens in the right pane.
- Select the ASP check box under Application Development in the list and click Next.
The Confirm Installation Selections page summarizes your actions and related messages.
- Click Install.
- Click Close.
The Installation Results page closes.
- Exit from the Server Manager window.
