CA Network Flow Analysis 9.1.2 supports upgrades of software versions installed on servers with the operating systems noted in the following table:
Software Version |
Operating System |
From RA 9.0.161 to NFA 9.1.2 |
Windows Server 2008 R2 Standard edition (all components) |
From RA 9.1.0 to NFA 9.1.2
Red Hat Enterprise Linux 5.5 or 5.6 (Harvester) |
From NFA 9.1.1 to NFA 9.1.2
CA Network Flow Analysis 9.1.2 supports Windows Server 2008 R2 Standard edition for all components. Windows Server 2003 is not supported at this time. For help upgrading your Windows operating system in preparation for the CA Network Flow Analysis upgrade, contact CA Technical Support.
If you add components on new servers to your upgraded configuration, you can install the software on servers with the following operating systems:
Note: If you have either of the following special situations, contact your CA Support Availability Manager to ask for help:
Microsoft Windows servers that host CA Network Flow Analysis components have the following additional operating system requirements.
Microsoft Windows 2008 R2, Standard edition on a 64-bit processor, with:
If the .NET Framework software is missing or version 4.0 is installed, the a prerequisite check causes the installation or upgrade program to exit.
If the installation server does not have JRE version 1.6 installed, the installation or upgrade program fails to launch. We recommend that you install JRE 1.6u41, the version that was used in CA Network Flow Analysis 9.1.2 testing. Untested JRE versions may produce unexpected results.
This command is required for command-line operation. If the file is missing, a prerequisite check causes the installation or upgrade program to exit.
Notes:
