Previous Topic: How to Back Up and Restore CA Network Flow Analysis DataNext Topic: Stop the Services
Databases to Back Up
CA Network Flow Analysis uses several databases to store configuration data, 15-minute (historical) data, high resolution (1-minute) data, and Enterprise Overview data. This topic describes databases to consider for backups and gives general recommendations for backup frequency. Data is used differently in different environments, however, so your priorities for safeguarding against data loss may vary.
All Servers
Single Sign-On Program (CA Performance Center)
Back up any customized Single Sign-On configuration settings on the CA Performance Center server regardless of your CA Network Flow Analysis deployment type. If you lose customized Single Sign-On settings, you may not be able to log into CA Performance Center and CA Network Flow Analysis.
NFA Console (Distributed Deployment)
Harvester (Distributed Deployment)
DSA (Three-Tier Distributed Deployment)
Standalone Server
