Previous Topic: How to Monitor CA Network Flow Analysis ComponentsNext Topic: View System Status
Edit Watchdog Service Settings
Edit the Watchdog settings to change configuration values such as thresholds, trap settings, polling settings, notification address, and community strings.
  1. Display the Watchdog Settings page:
    1. Select Administration from the NFA console menu.
    2. Select Health: Watchdog Settings from the Administration page menu.
      The Watchdog Settings page opens and displays the current settings.
  2. Edit the Watchdog Service settings:
    Community String
    SNMP string that is used to identify components in a distributed deployment. The Watchdog Services use the community string when gathering information from Harvesters (and from DSAs in a three-tier architecture deployment).
    Default: public
    CPU Threshold
    Threshold for CPU utilization. You are notified by email when the CPU threshold on a server is exceeded on any server and an SNMP trap notification is generated, provided that the address and string are set.
    Default: 80 percent CPU utilization
    Disk Threshold
    Threshold for disk utilization. If the disk threshold on a server is exceeded, you are notified by email and an SNMP trap notification is generated, provided that the address and string are set.
    Default: 80 percent disk utilization
    Email Address
    Destination email address to use for email notifications when thresholds are exceeded. To notify multiple recipients, separate the addresses with commas. The Email Address setting has no default value.
    Default: (none)
    Memory Threshold
    Threshold for memory utilization. You are notified by email when the memory threshold on a server is exceeded, provided that the address and string are set.
    Default: 80 percent memory utilization
    SNMP Retries
    Number of times the program attempts to poll an SNMP device. A high number of SNMP Retries can affect performance, depending on your network configuration.
    Default: 2
    SNMP Timeout
    Number of seconds before an SNMP poll times out.
    Default: 5
    System Check Interval
    Number of minutes between Watchdog system checks.
    Default: 60
    Trap Community String
    SNMP string to use for sending traps.
    Default: public
    Trap Destination
    IP address of the server that receives SNMP traps from the Watchdog Services. The traps are generated when thresholds for CA Network Flow Analysis component performance are violated.
    Default: (none)
  3. Click Save when you finish editing the settings.
