Previous Topic: Add ToS Values to the ToS GroupNext Topic: Delete ToS Groups
Change the Contents of ToS Groups
You can change the list of ToS values included in a ToS group to make corrections or to change the purpose of the group.
Note: ToS groups are independent of domains: The ToS values included in a ToS group do not change when you switch to a different domain.
  1. Select Administration from the NFA console menu.
  2. Select Groups: ToS Groups from the Administration page menu.
    The ToS Group Configuration page opens and displays information for the currently selected ToS group and domain.
  3. Select the ToS group to edit from the ‘Select a ToS group’ list.
    Note: You cannot edit built-in groups, such as the All ToS group in the Default Domain.
  4. (Multiple domain environment only) Select a domain from the Domain list, provided you have multiple domains available and you have created ToS labels that you want to display. ToS labels are domain-specific.
    Note: The Domain setting is displayed only if multiple domains exist.
  5. Click the Add/Remove link that is located above the list of ToS values included in the group.
    The ToS Index dialog opens. The ToS list displays the ToS labels that have been defined for the currently selected domain.
  6. Select or clear check boxes to include only the ToS values you want.
  7. Click Save when your changes are complete. The list of ToS values is updated.
