Previous Topic: Create Interface AggregationsNext Topic: Edit Multiple Interface Aggregations
Edit a Single Interface Aggregation
Edit a single interface aggregation to choose different interfaces to aggregate or to change the aggregation name, description, speed, or interface type.
  1. Display the Aggregations Interfaces page:
    1. Select Administration from the NFA console menu.
    2. Select Interfaces: Aggregations from the Administration page menu.
      The Aggregation Interfaces page opens and shows a list of the current interface aggregations.
  2. Click the check box next to the aggregation that you want to edit, then click Edit.
    The page changes to Edit Aggregation view, which includes editable options.
  3. Make any changes that are needed, such as adding or removing interfaces or changing the aggregation name, description, in/out speed, or type.
  4. Click Save.
    Your changes are saved and you return to the list of aggregations.
