Administering CA Network Flow Analysis › View Physical and Virtual Interfaces › Delete a Router
Delete a Router
You can delete a router that has stopped sending flows to CA Network Flow Analysis. If you delete a router, its historical data, interfaces, CVIs, and traps are deleted. The deletion also affects any aggregations, views, and reports that previously included the router.
- Verify that the router is no longer sending flows to CA Network Flow Analysis.
- Select Administration from the NFA console menu.
- Select Interfaces: Physical & Virtual from the Administration page menu.
The Active Interfaces page opens and shows the list of routers.
- Select the check box next to the name of the router that you want to delete.
- Click Delete.
A message opens to ask you to confirm the deletion.
- Click Yes in the confirmation message.
The following events result:
- The router is deleted and the confirmation message closes.
- All related historical data is purged permanently.
- All related interfaces, CVIs, and traps are deleted.
- The router is deleted from any related aggregations.
- The data for deleted interfaces no longer appears in custom reports or NFA console views.
- Any custom reports that are set to display only interfaces from the router are disabled.
- If you select Enable Interfaces from the Administration menu, the router is still visible on the Available Interfaces page even though it is no longer listed on the Active Interfaces page.
