When you have defined the Custom Reports that you need, you are ready to generate a new report and view it in the NFA console. You can run and view the following types of reports:
The Custom Reporting page contains two panes. The left pane lists the folders that store saved reports. The right pane lists the reports in the currently selected folder.
The report runs. The results are displayed when report generation is complete.
The default presentation type is Custom layout. The other available options are dependent on the filters that are defined for your report.
When you select an option other than Custom Layout, a Presentation menu is added on the left side of the page. You can select from the presentation types and from the data types to modify your view. For example, you could change from a pie chart to a stacked trend chart that shows volume.
