Previous Topic: Top N Hosts ReportNext Topic: Flows Report
Top N Conversations Report
A Top N Conversations report provides information about the hosts that generate the most traffic on the selected interface. This report includes information about the total data in the conversations.
A Conversatin Summary view A Protocol Summary view shows percentage of traffic by conversation.
To display a Top N Conversations report, start from an interface report.
  1. Display an interface report in either of the following ways:
  2. Select Conversations from the report type menu at the top-left corner of the page.
  3. Make sure that the report scope is set to Top N Conversations. The Top N Conversations link should appear next to the report type setting.
    The report page is updated to show a conversation summary pie chart by default.
  4. (Optional) Change the data presentation type and the data measurement type by using the Presentation options.
  5. (Optional) Change the reporting period: Open the Timeframe dialog by clicking the timeframe link.
    The reporting period is the most recent 24-hour period by default.
Display an Interface Report for a Single Conversation
To drill down to details about a specific conversation, click one of the conversation links in the Top N Conversations view. A report opens, which you can configure to show any of the following data:
You can view this type of report in Details mode or Protocols mode, which have the following options:
To return to the summary view of all conversations on the interface, click the link that is named for the currently selected conversation and click Select Top N Conversations.
Find Comparable Views in CA Performance Center
You can display the following conversation views in the CA Performance Center console:
