Previous Topic: Use the Interface IndexNext Topic: Open an Interface Report by Group
Open an Interface Report by Router
The Router tab in the Interface Index view displays a list of all routers that have been discovered in CA Network Flow Analysis. The list is sorted alphanumerically and displays 20 routers per page by default. Use this tab to locate an interface by router.
  1. Select Interfaces in the NFA console menu.
    The Interfaces page opens.
  2. Make sure the Router tab on the Interface Index page is displayed.
  3. Click the router name to expand a list of its interfaces.
  4. (Optional) Use one of the following functions to locate an interface:
  5. Click the interface that you want to investigate.
    An Interface Overview report opens, which displays data for the selected interface.
  6. (Optional) Change the format or type of data displayed in the report: Click the gray bar on the left side of the page to open the Presentation menu, select the desired display and metric options, then click the bar again to hide the menu.
    More information about the presentation options is in Set the Presentation Options.
