Previous Topic: Manage Email SchedulesNext Topic: Organizing Dashboards in Menus
Generate a URL for a View
You can export a view and share it with coworkers who do not have access to dashboards. CA Performance Center can generate a special uniform resource locator (URL) to recreate a selected data view on demand. The URL lets you add the view to a web page or intranet site to share performance data with coworkers. The Generate URL feature lets you involve others in capacity-planning and infrastructure upgrade decisions and lets you share status information.
  1. Log in as a user with the 'Generate URLs from Views' role right.
  2. Navigate to the dashboard that contains the view for which you want to generate a URL.
  3. Click the Edit icon Click the Edit icon to change view settings. on the view, and select Generate URL.
    The Generate URL dialog opens. The URL is displayed in the URL field.
  4. Enable or disable the following required parameters for the exported view:
    View Container
    Displays the chart or graph with a surrounding container. The container includes the title of the view in a title bar and a black outline around the chart or graph.
    Default: Enabled
    Copyright
    Shows the copyright information for the web page in the view if enabled.
    Drill Down
    Enables users to drill down from the view into the underlying data source for more detailed data. These users must have a minimal product privilege to the data source and the 'Drill into Data Sources' role right to use this feature.
    Default: Enabled.
  5. Select from the following time frame options:
    Time Options
    Let you change the time frame for the data in the exported view. Supply a custom time frame in the Start Time and End Time fields, or select a Time Range from the drop-down list.
    Token Expiration Options
    Control view expiration. The default, 'Never' expires, lets the exported view display indefinitely.
    If you want the view to expire, select a timeout period from the Token Expiration drop-down list. The URL includes an encrypted token that causes the view to expire after the specified timeout period.
  6. (Optional) Click Preview to see how the view looks with the options you have selected.
  7. Copy the URL displayed at the top of the page to the Clipboard.
  8. Paste it to the destination where you want to display the view.
  9. Click OK.
  10. The Generate URL window closes.
