Previous Topic: Service ManagementNext Topic: Performing Advanced Administration
Service Logs
The service logs are described in the following table and are identified by their names on Windows and Linux servers. The initial part of each path is the CA Network Flow Analysis installation path, such as the default locations--C:\CA\NFA on a Windows server or /opt/CA/NFA on a Linux Harvester server. The table lists the service log file names and locations, along with any available configuration file to control the log level setting.
Service / Log Information
Standalone
Harvester
Console
DSA
CA NFA Collection and Poller Webservices (Linux: nfa_collpollws)
Log: \Netflow\Logs\collpollws-wrapper.log
Yes
Yes
CA NFA Data Retention (Linux: nfa_dataretention)
Log: \Netflow\Logs\dataretention-wrapper.log
Yes
Yes
Yes
CA NFA DNS/SNMP Proxies (Linux: nfa_proxies)
Log: \Netflow\Logs\proxies-wrapper.log
Yes
Yes
Yes
Yes
CA NFA DSALoader
Log: \Netflow\Logs\dsaLoaderErrors-<yyy-mm-dd>.log
Yes
CA NFA File Server (Linux: nfa_filewebservice)
Log: \Netflow\Logs\fileserver-wrapper.log
Yes
Yes
Yes (3-tier)
CA NFA Harvester (Linux: nfa_harvester)
Log: \Netflow\Logs\harvester-wrapper.log
Yes
Yes
CA NFA Poller (Linux: nfa_poller)
Log: \Netflow\Logs\poller-wrapper.log
Yes
Yes
CA NFA Pump
Log: \Netflow\logs\pumpservice-wrapper.log
Yes
CA NFA Reaper (Linux: nfa_reaper)
Log: \Netflow\Logs\RealtimeReaperErrors<yyyy-mm-dd>.log
Yes
CA NFA RibSource
Log: \Reporter\RIB\NFA\webapps\NFARS\WEB-INF\logs\ application.log
Yes
Yes
DNS Proxy Web Service
Log: \ProxyServices\Logs\DnsProxyWSLog<yyyy-mm-dd>.log
Log level setting (NFA console only): \ProxyServices\Web.config
<add key="LogLevel" value="6"/> Default: 4
Yes
Yes
NetQoS MySql51 (Linux: mysql51)
Log: \MySql51\data\<server_name>.err
Yes
Yes
Yes
Yes
NetQoS NQMySql51 (Linux: nfa_mysqlCSE)
Log: \Netflow\Logs\oursql_5.1_error.log
Yes
Yes
Yes
Yes
NetQoS Reporter Manager Service
Log: \Reporter\Logs\Manager Service Log<yyyy-mm-dd>.log
Log level setting: \Reporter\bin\ ReporterManagerService.exe.config
<setProperties Severity="6" /> Default: 4
Yes
Yes
NetQoS Reporter/Analyzer General Services
Log: \Reporter\Logs\nqservErrors<yyyy-mm-dd>.log
Yes
Yes
NetQoS Reporter/Analyzer Pump Service
Log: \Reporter\Logs\PumpLog<yyyy-mm-dd>.log
Log level setting: \Reporter\NetQoS.ReporterAnalyzer.PumpService\bin\ NetQoS.ReporterAnalyzer.PumpService.exe.config
<setProperties Severity="6"/> Default value: 4
Yes
Yes
NetQoS Reporter/Analyzer Query Services (‘Reporting services’)
Automatic Groups task log: \Reporter\Logs\ManagerService_AutomaticGroupsLog <yyyy-mm-dd>.log
DNS task log: \Reporter\Logs\ManagerService_DnsLog<yyyy-mm-dd>.log
Maintenance tasks log: \Reporter\Logs\ManagerService_MaintenanceLog <yyyy-mm-dd>.log
Yes
Yes
NetQoS Reporter/Analyzer Report Service
Log: \Reporter\Logs\FlowForensicsLog<yyyy-mm-dd>.log
Log level setting: \Reporter\NetQoS.ReporterAnalyzer.ReportService\ bin\NetQoS.ReporterAnalyzer.ReportService.exe.config
<setProperties Severity="6" /> Default value: 4
To log each poll in addition to regular event logging:
<add key="VerboseLogging" value="True"/>
Yes
Yes
NetQoS Reporter/Analyzer Watchdog
Log: \Reporter\Logs\WatchdogLog<yyyy-mm-dd>.log
Log level setting: \Reporter\ NetQoS.ReporterAnalyzer.WatchdogService\bin\ WatchdogService.exe.config
Yes
Yes
