Previous Topic: Customize AS NamesNext Topic: Edit Autonomous System Names
Review the Autonomous System Names
Review the AS references in the interface reports for your enterprise and locate any AS numbers in use that have long or unclear AS references.
The interface reports that contain AS references are:
  1. Collect information about which AS names are used in interface reports for your enterprise.
    The list of all AS numbers and names is extensive. You will not want to customize every AS name in the list.
    For example, compile a list of commonly used AS names by examining AS reports or by asking operators which AS numbers they track.
  2. Display the AS Names page:
    1. Select Administration from the NFA console menu.
    2. Select Define an Application: AS Names from the Administration page menu.
      The AS Names page opens and displays information about the first page of AS values.
  3. Locate each AS with a name that you want to customize:
  4. Review the AS names that appear in the Description column.
    Once you have located a default AS name that requires customization, you are ready to edit the AS name.
