Previous Topic: Enterprise-Level ViewsNext Topic: Top Enterprise Protocols by Volume
Top Enterprise Hosts by Volume
The Top Enterprise Hosts by Volume view in CA Performance Center is a graph summary of the enterprise hosts with the highest volume of network traffic, as reported by CA Network Flow Analysis.
The view shows which enterprise hosts generate the most network traffic.
The view shows a bar for each of a maximum of ten hosts who generated the highest traffic volume. The bar chart includes the following information:
Host
Identifies the host server by its name and IP address (Y-Axis). If an administrator defined an alias for the device item, the alias is displayed. Otherwise, the discovered device name is displayed.
Volume
Measures the total amount of data that was exchanged with the host (for example, in number of megabytes or gigabytes) (X-Axis).
By default, views and reports show the most recent 24 hours of data.
To see the Top Enterprise Hosts by Volume view in CA Performance Center, go to one of the following locations:
Available Actions for This View
You can perform several actions in this view, including the following actions:
Find the Comparable View in the NFA Console
The Top Enterprise Hosts by Volume view in CA Performance Center is similar to the Top Hosts view on the Enterprise Overview page in CA Network Flow Analysis.
