Many views offer a search feature and other settings that you can change to modify the view. In addition to filtering and time frame options, the following options are available for most data views:
Note: Users with the 'Save Changes to Shared Views' role right can save view modifications to their own user account. The changes persist after logout. However, other users cannot see changes to views.
Other view options are specific to the selected view. The available options depend on the format and data source.
The trend views that are available in context pages let you quickly and easily change the trend lines that are displayed on the graph. The following options also apply to multitrend views:
Trend views also include an option to add a "goal line" as a visual indication of performance levels or thresholds. You can supply any value or label for the goal line, and you can show or hide the goal line for a selected trend view.
In table views, you can drill down to detailed data for individual items. Use the page feature to see metrics from a longer list of items. Increase the Max Per Page value to increase the size of the view and the number of table rows per page.
You can sort table data columns by selected metrics and also select columns to include. Click a table column to sort. A white arrow on the column lets you access a menu of table column options. Select Columns to enable and disable the metrics that were enabled for the table by default.
The browser view is a unique view type that lets you add any URL to a selected report page. You can use this view to compare external factors alongside your network performance views. Also, the browser view lets you update internal and external data dynamically.
Multiple external factors can affect the performance of your network and servers, such as world events and adverse weather conditions. The ability to view a weather map and news headlines alongside performance data views on a single report page can help you better understand patterns in network performance.
When a view does not display CA Infrastructure Manager Data Aggregator data, this option lets you drill down directly to the CA Infrastructure Manager Data Aggregator Admin page to troubleshoot monitored devices and items.
You can change several settings for an enterprise-wide view or an interface-specific view. The available settings depend on the view that you are editing.
For example, some views have settings for data direction--so you can set the view to display inbound data, outbound data, or all data. Other views have settings for the type of measurement--so you can set the view to display data rates, data volumes, or interface capacity utilization.
The View Settings dialog opens.
Note: You can change the interface for an individual view on a custom dashboard that you defined with the Interface context. You cannot change the interface for standard views on other types of dashboards or on interface context pages.
To re-sort the table, click a column heading. You can click the white arrow to choose between Sort Ascending and Sort Descending.
To change the columns that are included in the table, display the Columns list: Click near the right edge of a column heading, then click the white arrow and select Columns.
For example, to restrict the interface set to a domain, select the domain from the IP Domains list.
Note: The availability of these options depends on your user account role rights.
The View Settings dialog closes. The view refreshes to reflect your updates.
Note: You can also change the context for a dashboard, which applies the selected group or managed item as a filter to all views on the page.
| Copyright © 2013 CA. All rights reserved. |
