Set a Custom Time Frame
You can select a precise time frame for the performance data shown in the current dashboard. You can select the day, the start time, and the end time using the time period selectors.
- Navigate to a dashboard.
- Click the date links in the upper-left corner of the dashboard page to open the calendar panes.
- Select the beginning day and ending day of the new time period on the calendar panes.
- Click the hours or minutes links to specify the beginning and ending times of the new time period.
- Click Set.
The custom time frame is applied to the dashboard you are viewing.
