You can delete a router on the Active Interfaces page. Deleting the router in this way effectively deletes its interfaces so you reclaim the storage capacity that the interfaces used. The router is not deleted from the system entirely.
If you delete a router, its historical data, interfaces, CVIs, and traps are deleted. The deletion also affects any aggregations, views, and reports that previously included the router interfaces.
The Available Interfaces page opens.
You can select and disable multiple routers simultaneously. All of the selections must be on the same display page, however. Moving to a different page clears any selections that you made on the previous page.
A confirmation message opens, which asks if you want to disable all the interfaces for the router.
The Enabled status is changed to No for the interfaces. New data from the interfaces is no longer collected or shown in reports, but data that is already collected is still available for reports.
The Active Interfaces page opens, which lists the current routers and their active interfaces.
A confirmation message opens, which asks you to confirm the deletion.
The following events result:
The router is not deleted from the system permanently. If you enable its interfaces and the interfaces begin to send flow, the router reappears on the Active Interfaces page.
Also see:
| Copyright © 2013 CA. All rights reserved. |
