The TTL Expired Sources sensor looks for possible router misconfiguration, such as routing loops, by monitoring for time to live (TTL) expiration messages.
Troubleshooting a TTL Expired Sources Alert
An alert from the TTL Expired Sources sensor may indicate one of the following issues:
Try to identify and correct any network outage that becomes apparent. Try to find any "black hole" network ranges and check the associated routers.
Investigate any unusual traceroute activity to determine whether the activity is legitimate. For example, investigate whether the traceroute activity is performed for testing or troubleshooting.
