You have the option to set an absolute threshold so that alerts are generated when the threshold is violated, provided that alerts are enabled. Absolute thresholds are applied before probability thresholds.
The following table lists the sensors and units of measure for absolute thresholds.
Sensor |
Looks For: |
Unit of Measure |
Buffer Misses |
Pattern in buffer misses |
buffer misses |
Congestion Sources |
Sources of overloading based on ICMP Source Quench |
flows |
Destination Unreachable Sources |
High-volume sources of network, host, or port unreachable messages |
host or port unreachable messages |
Dropped Packets |
Pattern in queue drops |
dropped packets |
Fragmented Packet Sources |
Large sources of fragmented packets |
Frags And Loss Sources |
Sources of fragmentation and packet loss |
flows |
High and Variable Vol-In |
Highest-volume and variability destinations |
bytes in |
High and Variable Vol-Out |
Highest-volume and variability sources |
bytes out |
High Flow Sources |
Top sources of data flows |
flows |
High Packet Fan Out |
Sources of the largest fan-out traffic patterns |
destination hosts |
Incoming Discard Rate |
Pattern in incoming discards |
discard rate |
Incoming Error Rate |
Pattern in incoming errors |
error rate |
Large DNS Packet Sources |
Large sources of DNS packets that are larger than normal |
flows |
Large ICMP Packet Sources |
Large sources of ICMP packets that are larger than normal |
flows |
Non-local Sources |
Top sources of non-local traffic |
non-local traffic |
Packet Load |
Pattern in bytes per packet to server |
bytes per packet |
Previously Null Routed Srcs |
Hosts with high volumes of traffic that is no longer null-routed |
flows |
Refused Sessions |
Pattern in refused sessions |
percent |
Retransmission Time |
Pattern in retransmissions |
seconds |
RST-Only Sources |
Highest-volume sources of RST-only flows |
flows |
SYN/RST-Only Packet Srcs |
Highest-volume sources of SYN/RST-only flows |
flows |
SYN-Only Packet Sources |
Highest-volume sources of SYN-only flows |
flows |
TTL Expired Sources |
High-volume sources of TTL expired packets |
flows |
Voice Call DoS |
DoS in voice calls |
calls per minute |
Voice Call Fan Out |
Pattern in fan-out of voice calls |
call ratio |
Voice Server Distress |
Call Server Distress |
Volume Weighted Error Ratio |
