CA Anomaly Detector is highly scalable. The program does not retain a lot of data: It collects and analyzes only the results of data analysis from CA NetQoS Performance Center data source products.
The MySQL database does not become overloaded easily. For example, after several weeks of running CA Anomaly Detector at a large enterprise, the database growth rate was equivalent to 4 GB per year. The typical growth rate in testing is 160,000 database rows per day.
CA Anomaly Detector can handle 1 million flows per minute for CA Network Flow Analysis.
We support using a single instance of CA Anomaly Detector to monitor the following data sources:
