Preparing Windows Servers › Install IIS, ASP, and COM+ › Install IIS, ASP, and COM+ on Windows Server 2003
Use the steps in this topic to install the following required components on a standalone server or NFA console server that is running Windows Server 2003:
- ASP.NET
- Network COM+ access
- Internet Information Services (IIS)
with the Active Server Pages option enabled for the World Wide Web service
- Log in to the server as a user who is a member of the Administrators group.
- Open the Windows Component wizard:
- Select Start, Control Panel, Add or Remove Programs.
The Add or Remove Programs window opens.
- Click Add/Remove Windows Components in the left pane.
The Windows Components Wizard window opens.
- Select the components to add:
- Select Application Server in the list.
- Click Details.
The Application Server dialog opens and displays a list of optional Application Server components.
- Select the following check boxes:
- ASP.NET check box.
- Enable network COM+ access (selected automatically when you select ASP.NET)
- Internet Information Services (IIS) (selected automatically when you select ASP.NET)
- Select the Active Server Pages subcomponent to be enabled for the World Wide Web service:
- Select Internet Information Services (IIS) in the Application Server component list.
- Click Details.
The Internet Information Services (IIS) dialog opens and displays a list of optional IIS subcomponents.
- Highlight the World Wide Web Service subcomponent. This check box is selected by default.
The World Wide Web Service dialog opens and shows a list of subcomponents.
- Select the Active Server Pages (ASP) check box.
- Save your selections:
- Click OK in the World Wide Web Service dialog.
You return to the Internet Information Services (IIS) dialog.
- Click OK in the Internet Information Services (IIS) dialog.
You return to the Application Server dialog.
- Click OK in the Application Server dialog.
You return to the Windows Component Wizard.
- Update the Windows configuration with your selections:
- Click Next in the Windows Components Wizard screen.
The system locates the files for the update. If any files are missing, a message opens. In this case, insert the Windows 2003 Server Edition CD-ROM or specify the path to the missing files.
A message notifies you when the preparations are complete.
- Click Finish.
The Windows Components wizard closes. The Windows configuration changes are complete.
