We recommend that you set up Windows Server 2008 R2 systems so that they are prevented from connecting to IPv6 addresses, which are currently not supported. If connection to IPv6-formatted addresses is enabled, data collection fails. This topic describes how to perform this task on the Windows Server 2008 R2 systems in your CA Network Flow Analysis deployment.
Note: Windows Server 2003 systems disable connection to IPv6 addresses by default. You do not need to perform this task on a Windows Server 2003 system unless the "Microsoft TCP/IP version 6" option has been enabled for network connections.
Required/Optional |
Operating System |
Servers to Configure |
Recommended |
Windows Server 2008 R2 |
All servers |
The instructions are based on the assumption that each server has a single network interface card, which is the recommended configuration.
The Network Connections window opens and shows the currently configured connections.
The Properties dialog opens.
Any changes that you made are saved. The Properties dialog box closes,
The Network Connections window closes.
