Post-Upgrade Tasks › Synchronize System Time › Synchronize System Time on Windows Server 2008 R2
Complete the steps in this topic on each Windows Server 2008 R2 in your deployment, unless the system time is synchronized automatically.
- Log in as a user who is a member of the Administrators group.
- Right-click the date or time on the right edge of the taskbar and select 'Adjust date/time.'
The Date and Time dialog opens.
- Click the Internet Time tab.
- Click 'Change settings.'
The Internet Time Settings dialog opens.
- Select the check box labeled 'Synchronize with an Internet time server.'
- Select the server with which you want to synchronize. The default is time.windows.com.
- Click 'Update Now.'
The system time is synchronized with the selected server.
- Click OK in the Internet Time Settings dialog.
- Click OK in the Date and Time dialog.
Note: If you have collection devices in different time zones, set each device to its local time zone. Times are converted to Greenwich Mean Time (GMT).
