Previous Topic: Install JRE and .NET FrameworkNext Topic: Firewall Configuration
Install Adobe Applications
Adobe Flash Player is used to view reports and the Administration System Status page. We recommend that you install the latest version of Flash Player from http://get.adobe.com/flashplayer/.
Adobe Acrobat Reader is required on any system that you use to view the product documentation in PDF format. If you do not have a recent version of the Acrobat Reader, install the latest version from http://get.adobe.com/reader/.
Required/Optional
Operating System
Servers to Configure
Recommended
Windows Server 2003. Windows Server 2008 R2
Standalone, Console
