Related Documentation
CA provides a full set of technical documentation in the CA Network Flow Analysis Documentation Bookshelf. Access the bookshelf by clicking the Help link in the CA Network Flow Analysis user interface. You can open the guides in PDF and HTML format from the Documentation Bookshelf. Access the bookshelf from the Help menu in the CA Network Flow Analysis or CA Performance Center user interface.
The documentation may have been updated since its release. To be sure you have the latest documentation updates, download the bookshelf and Readme files from CA Support. |
The documentation set for CA Network Flow Analysis 9.1.3 includes the following guides:
The product PDFs are in the following directory: <install_path>\Reporter\NetQoS.ReporterAnalyzer.WebSite\help\<locale>\NFA_Bookshelf\Bookshelf_Files\PDF.
To view the documentation PDF files, make sure that Adobe Reader is installed. You can download the Reader from http://get.adobe.com/reader/.
