CA Network Flow Analysis uses several databases to store configuration data, 15-minute (historical) data, high resolution (1-minute) data, and Enterprise Overview data. This topic describes databases to consider for backups and gives general recommendations for backup frequency. Data is used differently in different environments, however, so your priorities for safeguarding against data loss may vary.
All Servers
Location: Files with an .config, .conf, or .ini extension that are located anywhere in the CA Network Flow Analysis installation path
Recommendation: Daily backup
Single Sign-On Program (CA Performance Center)
Back up any customized Single Sign-On configuration settings on the CA Performance Center server regardless of your CA Network Flow Analysis deployment type. If you lose customized Single Sign-On settings, you may not be able to log into CA Performance Center and CA Network Flow Analysis.
NFA Console (Distributed Deployment)
Recommendation: Weekly backup
Harvester (Distributed Deployment)
Location: <install_path>\Netflow\datafiles\ReaperArchive15
Locations: <install_path>\MySql51\data\harvester and <install_path>\MySql51\data\poller
Location: <install_path>\Netflow\datafiles\HarvesterArchive
Many administrators do not back up Flow Forensics data because of its short storage life--a maximum of 24 hours.
The 1-minute data is stored for one month.
Note: It is unusual to customize data retention settings, except with the assistance of CA Support. Changes to data retention settings can cause problems as the demands on drive space rise.
DSA (Three-Tier Distributed Deployment)
Standalone Server
Many administrators do not back up Flow Forensics data because of its short storage life--a maximum of 24 hours by default.
The 1-minute data is stored for one month by default.
