Previous Topic: Define Templates for Interface Names and DescriptionsNext Topic: Conventions for Interface Templates
Create a Custom Interface Template
Create a custom interface template to change the way all interface names and descriptions appear in the NFA console. By creating an interface template instead of editing the current template, you can make it easy to experiment with different formats.
  1. Display the Interface Templates page in the NFA console:
    1. Select Administration from the NFA console menu.
    2. Select System: Templates from the Administration page menu.
      The Interface Templates page opens.
  2. Click Add.
    The Interface Templates page displays options for adding an interface template.
  3. Specify the interface template settings:
    Use properties from the following list for both settings:
  4. Click Submit.
    The new template is created and is added to the template list. The extra options are removed from the Interface Templates page.
  5. (Optional) Apply the template: Select the template from the list at the top of the Interface Templates page.
    The template is applied to the NFA console almost immediately. The CA Performance Center views that use the template reflect the changes at the next synchronization, which occurs automatically within 5 minutes.
  6. (Optional) Review the results of changing the template. For example, review the new labels on Interface pages and on the Enterprise Overview page.
