Previous Topic: Configure the Protocol GroupNext Topic: Label ToS Values
Review and Revise the Protocol Group Settings
After you create a protocol group and operators use it in reports, you may want to make changes. For example, you may want to rename the protocol group to reflect the way operators are likely to use it. You also may want to change the list of protocols included in the group.
  1. Select the protocol group from the ‘Select a Protocol Group’ list on the Protocol Group Configuration page.
  2. (Optional) Edit the name or description of the protocol group:
    1. Click Edit.
      The Edit a Protocol Group page opens.
    2. Change the values for the Group Name and Description fields to help identify the purpose of the protocol group more clearly.
    3. Click Submit.
      The name and description are updated in the Protocol Group Configuration page list and in the Protocol Group Index.
  3. (Optional) Review and revise the list of protocols that are included:
    1. Click List.
      A table is added to the bottom of the page, which lists the protocols.
    2. Select the appropriate domain from the Domain list, if custom protocol names have been defined.
      The Domain setting is displayed only in an environment that has multiple domains.
      For more information about the Domain setting, see step 3 in Configure the Protocol Group.
    3. Click Add/Remove and change the contents of the protocol group as needed
      For more information about this step, see step 4 in Configure the Protocol Group.
    4. Click Done when you finish configuring the contents of the protocol group.
    The protocol group is configured with your settings. Operators can select the reconfigured protocol group as a filter for an Analysis or Custom report.
