Previous Topic: Create a Shell ToS GroupNext Topic: Change the Contents of ToS Groups
Add ToS Values to the ToS Group
After you create a shell ToS group, the next step is to add values to the ToS group.
  1. Select the ToS group from the ‘Select a ToS group’ list on the ToS Group Configuration page.
  2. (Optional) Select a tenant-domain combination from the Domain list, provided that multiple domains exist and that you have created some domain-specific ToS labels.
    If only one domain exists, no Domain setting is displayed.
    By selecting a tenant-domain combination, you display any available domain-specific ToS labels, which help you identify the ToS values to use. The ToS group will not be restricted to the selected domain: ToS groups are available in all domains.
  3. Click Add/Remove.
    The ToS Index dialog opens. The ToS list displays the ToS index values and the ToS labels that have been defined for the currently selected domain.
  4. Select the ToS values to add by clicking their check boxes.
  5. Scroll to the bottom of the list and click Save.
    The ToS values are added to the ToS group.
    An operator can select the ToS group from the ToS Group Index when defining an Analysis or Custom report.
    Note: To define reports, the operator must have the necessary role and permission group settings.
