Views in CA Performance Center › Customizing Views › Change the Context for a View
You can change the context for a single view on a dashboard. Change the context of an enterprise-wide view to show data from a different set of managed items. Change the context of an interface-specific view to show data from a different interface.
Changing the context for a view is useful for troubleshooting performance issues. For example, you can use your group structure to compare data from different geographical regions.
- Open the dashboard that contains the view that you want to modify.
- (Optional) Change the time frame, if necessary.
- Click the Edit icon
in the view title bar and select Edit from the menu.
The View Settings dialog opens.
- Take one of the following steps:
- Enterprise view: Click to expand folders in the Groups filter tree, and select the group whose data you want to see in the view.
- Interface view: Locate the interface whose data you want to see in the view, and click the link in the table.
- Change the view Title to reflect the new context.
The context types that are available depend on the type of view.
- Select the scope of your changes from the Apply Changes drop-down. Select one of the following options:
- For All Tenant Users: Saves the changes so that they are only available to users associated with your tenant (possibly the Default Tenant).
- My User Account: Saves the changes to your user account as a default for this view.
- My Current Session: Reverts the changes when you log out.
Note: The availability of these options depends on your user account role rights.
- Click Save.
The view is updated with data from the new context.
You can also change the context for a dashboard, which applies the selected group or managed item as a filter to all views on the page.
