Verify that each Harvester is associated with the appropriate tenant-domain combination before you set up routers to export flow data. If you have not already done so, set up any needed custom tenants and domains before you proceed.
The Harvester page opens and displays the current list of Harvesters.
The Edit Harvester dialog opens.
Default: Default Tenant \ Default Domain.
You can also change the IP Address and Description.
If no custom IP domains have been created, the Harvester table includes only the IP Address and Description columns.
Your changes are saved immediately.
